Hi. I am receiving an error E210 from my canon NP1215 when i just swtch it on, whats the issues, help....
E210
If I remember well, if you detach the back cover, you can see an upright axle on the upper middle section.
In this axle a solenoid makes a gear sliding up and down. There is only one motor.If a solenoid is off, the motor rotates only the scanner. If it is on, the motor moves the scanner and a lens too. If the metallic axle has dryed grease, it switches too slow. The motor
moves the lens into home position with the scanner, and then would like to move the scanner without the lens to home. But with stucked axle the lens moving too, unfortunately out from home position.Comment
If the lens does not return to the
home position (LHP remains 0)
within 2.5 sec.
If LHP remains 1 for at least 4 sec.
1. Clean (repleas) sensor.
2.Check all conection on the DC Contr. PCB
Fuser sensor & leans home positon sensor the identical
Change in places
Canon NP1215 & NP1520 it is old & very good mashin`sLast edited by gensys; 04-19-2011, 09:30 PM.The Road will be Mastered by >>> the Going...Comment
