ir3300 paper jam
  • jiongpao
    • May 2009
    • 413
    ir3300 paper jam
    its a first time i encounter a jam on registration roller. The paper totally cannot get through it. Pickup solenoid changed still the same.
    should i try to change Registration paper sensor and registration motor (m9)?
  • mrfixit51
    Lead Service Technician
    • 1975
    Disassemble the registration area and look for a bind, check to make sure you have rotation of the registration roller, check the clutch. Post jam codes for better assistance...
    • jiongpao
      • May 2009
      • 413
      its totally not rotating when i open pickup cover i can easily pull out the paper. i double checked with disassemble the unit nothing jam or stuck inside. 5 out of 10 will same at same place.
      • charm5496
        • 2387
        need the jam code to help you out
        • mrfixit51
          • 1975
          Amen to that...
          • costd
            • Jan 2008
            • 409
            Sorry to ask, but you did check the paper orientation and dial settings right? Along with the jam code, does it do it from all the paper drawers and the bypass?
            • jiongpao
              • May 2009
              • 413
              Thanks guys Registration paper sensor changed everything fix without even a single jam.
              • mrfixit51
                • 1975
                Good to hear that,, was the sensor arm actuator worn down, did you put an extra wrap on the spring???
                • jiongpao
                  • May 2009
                  • 413
                  Yes mrfix, i did turn another circle for the spring after i changed the sensor.
