Canon IR3570 curl on 11x17
  • Morales3556
    • Apr 2011
    • 14
    Having issues with paper curl on the exit path with 11x17. It seems the flapper is causing the paper to curl and is putting indentations on the paper. Only does this on 11x17. Any help would be appreciated.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    There were 2 back up rollers that were supposed to be removed in the top of the paper path, I don't have the images handy. If you research 0107 jamming here in this forum, you may run across the pictures I am referring to. Or Teckat will pop up with them, they may be the source of your issue...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Did you mean this picture?
      • teckat
        • 16083
        Ledger size paper is wavy==
        Change the value of FX-FL-SP in service mode to +3.
        To change the value of FX-FL-SP in service mode, perform the following.
        Service Mode > Copier > Adj > FX-FL-SP
        Use it to enter a fine adjustment value for the fixing film speed when plain paper is used. Make a fine adjustment of the target control speed for the fixing film speed when plain paper is used.
        Setting range:
        -3 to 3 (Default: 0) (Unit: ms)
        inspect or replace the 2nd Delivery Unit, part number
        FM2-1328-050
        • teckat
          • 16083
          think that was for 0207 codes on all size paper /
          l
          ead edge of the paper is stopping at or just before the delivery rollers w/z fold trail edge/
          at fixing/delivery sensor PS13
          anyway it does not hurt to remove them
          • mrfixit51
            • Oct 2008
            • 1975
            Yes sir, thanks Teckat!
