IRC3100 printing.
  • osmani
    • Jun 2010
    • 38
    IRC3100 printing.
    How can I use IRC3100 to print at 300dpi? shall be thankful for any guidance.
  • teckat
    • 16083
    Check under Add Functions-[Printer Settings> Settings> Print Quality>Resolution
    iRC3100
    Copying resolution 600 x 600 dpi
    Printing resolution 600 x 600 dpi
    Reading resolution 600 dpi (main scanning direction) x 600 dpi (sub scanning
    direction)
    Because of a specification constraint, [PDF (Compact)] cannot be selected if you select a combination of "Color Mode" and "Resolution" other than the following three.
    - Auto-Color Select (Full Color/Grayscale) 300x300dpi
    - Full Color 300x300dpi
    - Grayscale 300x300dpi
    If you want to select [PDF (Compact)] as a file format, select either of the combination's above.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      May I ask why you want to print at 300 DPI?
      Is 300 DPI not an option in the print driver? (I haven't seen a driver for that model in a really long time.)
      • osmani
        • Jun 2010
        • 38
        Thanks Mr.TECKAT. We use 300 dpi. to make screens for printing.
