imageRUNNER ADVANCE C5051/45/35/30-E009-0002 Error Codes
    • 16083
    [Error Code] imageRUNNER ADVANCE C5051/45/35/30-E009-0002 Error Codes
    Measure to Prevent Noise in the Fixing Assembly - E009-0002 Error Codes
    This informs the field that Error Code E240-0004 has been changed to E009-0002/due to the update revision of DCON from v60.01 to v61.02.
    Publication describes a cleaning process that will help minimize a thumping noise and E009-0002 Error Codes.
    TP10-1.pdf
    Cleaning_Procedure.pdf
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    Cheers.
    Gotta admit not came across E240 / E009 yet on my 50XX Machines.
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Originally posted by CanonSco
      Cheers.
      • CanonSco
        Man About Town
        • Jul 2010
        • 368
        Originally posted by zoraldinho
        [ATTACH=CONFIG]9510[/ATTACH]
        hahaha.
        Considering I had the first 50XX's in my country, 60+ in one go , and have had every possible issue with them. I am glad this has not reared its head yet. Although the fix looks ok.
        Yes, I am a nerd.
        • glenno
          Thanks. This thread has really helped me out.
          Glenn
          • prntrfxr
            • 1622
            Re: imageRUNNER ADVANCE C5051/45/35/30-E009-0002 Error Codes
            I'm not that familiar with Canon machines and this is one of our test machines. I have E009-0002 Errors and Jam Errors (0CF1, 0A01, 0A02). Paper stops at the registration asm, does not enter fuser, and is not crumpled in any way. Jams occur whether printing from Bypass, Tray 1 or Tray 2. There is a thumping noise that occurs during warm-up and during printing.
            We performed the cleaning procedure you recommended, added pressure to the leaf spring, and we are still getting the above errors. What, in your opinion should be our next step?
            • prntrfxr
              • 1622
              Update:
              We bent the leaf spring more and error went away. It is working now without jamming, thumping noise is gone but a clicking noise remains.
              • zoraldinho
                • Mar 2008
                • 5015
                Update
                Measures against the noise on the fixing assembly and E240-0004/E009-0002
                • corbeer
                  Update
                  We have had this error now on 3 machines, a iRAdv5030i, a iRADv5045i and a iRAdv5051i, with varying degrees of successful fault completion! We started out doing the grease clean and spring re-tension as per the bulletin, but this didn't cure it on all of the machines. Fortunately we had a used machine that had just come back after a lease agreement that we nicked the fuser out of, put this in the first faulty machine, flashed the software and this one is fine. Strangely though we took the previously erroring fuser out and put that in our ex lease machine and that's been fine! We now have one MIF that is constantly falling over with the E0009 version of the error (we have haven't updated the software yet)....so my question is do you know of any reason that the software versions could be either helping to get over this error or possibly causing it? All the machines have been completely degreased and we went so far as to change the cams and the springs on all of them but we are still getting this issue on 2 of them, but even with swapping the fusers around one machine (with the older software revision on it) is definitely being more problematic than the others. please let me know....
                    • 16083
                    July 12, 2013
                    E009-0002
                    replacing the sensor holder unit for the pressure cam sensor resolved the error. The part number for the sensor holder unit is FM3-5953-000.
                    Did u see these---------pdf's
                    E009-0000.pdf
                    Minimizing E009-0000 Error Codes.pdf--08-19-13
                    • Canuck
                      Tech Specialist
                      • 1713
                      Read this...had many of these...
                      • techandtrader
                        • Jun 2016
                        • 335
                        Originally posted by prntrfxr
                        Update:
                        The clicking means that the Fuser Drive gear assembly needs to be changed. Its not an emergency but eventually jams will take over. A new fuser drive set will eliminate the clicking noise and the weird jam!
                        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                        • zoraldinho
                          • Mar 2008
                          • 5015
                          I believe these models are no longer in use. At least not in our country. This is a 14 year old post!😁
