canon image runner 2530i
  • ciaran
    • Mar 2011
    • 45
    hi all, have a problem with an ir 2530i, comes up with an error code E000001, no sub code, on start up, fuser only 3 weeks old, any ideas
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    [QUOTE=ciaran;215294]hi all, have a problem with an ir 2530i, comes up with an error code E000001, no sub code, on start up, fuser only 3 weeks old, any ideas[/QUOTE
    For start you didn't say what do you inspect.Do you check fixing film,heater,connectors.....
      • 16083
      This is how the code is read=E000-0001 Error Code
      did company experience a power outage ??
      did u attempt to clear in service mode ??
      ADDITIONAL FUNCTIONS> 2 KEY> 8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ERR
      if that won't work try=
      ADDITIONAL FUNCTIONS>2 KEY>8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>
      ENGINE>ERRCLR
      this mode should be used to clear all Fixing related Error Codes on this model-
      • ciaran
        • Mar 2011
        • 45
        checked all connections in fuser, checked film all seem ok
        ENGINE>ERRCLR
        function>clear>err only clears e719
        actualy did function>clear>all error still comes up, does clear all include engine>errclr
        • zoraldinho
          • Mar 2008
          • 5013
          We can't repair your issue true the network.Show some will dude!
            • 16083
            from the Manual
            > follow instructions------
            E000 0001 =Fixing temperature abnormal rise
            Description =The temperature detected by the main thermistor does not rise to the specified value during startup control.
            Remedy=
            1.Go through the following to clear the error:
            CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
            2.Check connection of the Connectors (Thermistor Connector and AC Connector).
            3.Replace the Fixing Main Thermistor (Film Unit).
            4.Replace the Fixing Assembly.
            5.Replace the DC Controller PCB (PCB4).
            • ciaran
              • Mar 2011
              • 45
              thanks teckat, i'm servicing this copier for another company,so they are sending me a new film,
              cutomer is badly stuck with copier not running so i was just trying to find some way of fixing even though i kind of knew i couldn't without the part, don't actually have any of these models in the field ourselves, so unfortunately don't have a manual for it.
              • zoraldinho
                • Mar 2008
                • 5013
                Finally some info!!
                • ciaran
                  • Mar 2011
                  • 45
                  thanks lads, i was going by the ir2016 manual as its the closest i had to that machine, error codes are the same but other features are different, really wish these smaller machines had full screen service modes like their bigger brothers
                  • zoraldinho
                    • Mar 2008
                    • 5013
                    amen
                    • ciaran
                      • Mar 2011
                      • 45
                      thanks teckat,
                      clear>engine>errclr solved my problem
                        • 16083
                        thanks teckat,
                        great~~~~~~~~~~~~~
