IR5000 : How to force to copy/print ONLY face up
  • skkn
    • Aug 2025
    with IR5000
    Can I (and How to) force to copy/print ONLY face up
    Why..
    cause I can run with face up copy Over 1,000 copy with out Jam
    But for copy/print with face down ,It 's Jam So much (Jam Code 020F)
    (I changed all new Upper Sept. claw for few day ago)
    Plaee give me some idea....
    Thank.....
  • gensys
    • Jan 2011
    • 323
    Originally posted by skkn
    with IR5000
    Why..
    Thank.....
    020F stationary jam at the claw sensor (PS4).
    check > Motor Driver PCB
    The Road will be Mastered by >>> the Going...
    • Brian8506
      • 1666
      Check white inverter gate arm on rear of delivery unit for cracks. Have you changed inverter roller. How many copies on machine?
      • 20YRSEXP
        • Oct 2008
        • 281
        Brian sounds like he is in the correct area. fix the problem instead of working around it or it will just be issues later on something else. the white arm usual breaks and you cannot see it while it is in the machine. Take it out and examine it. The white arm should have a fork on the end that goes around the solenoid pin and one of the forks usually breaks.
        Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
        • teckat
          • 16083
          with IR5000
          Why..
          Thank.....
          Replace the inverter rollers -
          • 20YRSEXP
            • Oct 2008
            • 281
            before replacing anything is the paper lying flat and pointing towards the exit or bending down towards the duplex unit? If it is flat and facing towards the exit then rollers and sensors probably having nothing to do with it. If it is heading down to the duplexer (the correct position) then rollers and or sensors are more likely the issue.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Even if you were able to force printed side up delivery, you would not be able to create 2 sided copies, as the same mechanism that is used to flip the copies over for face down delivery is also part of the 2 sided copies path. For my money, you will probably find the white guide actuator, already mentioned above, is cracked...
              EXTERNAL DELIVERY UPPER ASSEMBLY.pdf
              • skkn
                I 'm not a tech, and don't good at english. But I would like to say
                thank you for all reply , and Special thank to Brian8506 who point me to correct area
                • Now I can solve my problem by Add 1 stronger spring to white inverter gate arm ,But it 's still have some jam with Jam Code 0110 ,sometime 0114
                And Again, Thank for all ,who build up/Joining this forum
                It 's very helpful for me.
                • Brian8506
                  • 1666
                  You need to replace that arm. Its probably got a hairline crack.
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Part and part number are displayed in my file attachment in my previous posting...
                    • Canuck
                      Tech Specialist
                      • 1713
                      Replace the internal delivery roller assembly(has grey rolls on it) and the gear on the end of it. The gear has a one-way in it. Shaft gets chewed up also.Something to look at...changed many for 020F jams...usually around a million will start to act up. Same on 5570,5055 family
                      • andalasgt
                        • Oct 2010
                        • 49
                        Can you show the pictures ? Thank you
                        • andalasgt
                          • Oct 2010
                          • 49
                          If you don't mind, can you show me how to replace the inverter rollers. Thanks ...
                          • teckat
                            • 16083
                            Originally posted by andalasgt
                            if you don't mind, can you show me how to replace the inverter rollers. Thanks ...
                            fb6-5895-000
                            =#73-fixing/feeder frame assembly
                            [ATTACH=CONFIG]10078[/ATTACH]
                            • andalasgt
                              • Oct 2010
                              • 49
                              Thank you, I will learn it. ...
