irADV c5055i
  • macuk
    • May 2009
    • 90
    [CQ] irADV c5055i
    Am new to this model. Have deletions in magenta only from leading to trailing edges along the rear of the copy. Looks like lack of dev on mag roller. Machine said toner was low but not empty. Adjusted setting in service mode to allow toner flap opening and changed magenta toner bottle. Ran a few copies then gave magenta a stir in service mode . After 30 copies fault came back.Does this machine have a part no. For the developer or do you need to change the whole dev assembly? Is there anything else I can do to cure this fault?I would be grateful for any help!
  • teckat
    • 16083
    NO ON DEV. CHANGE
    check the D cut portion of the drive gear , it can strip out and not allow drive to the developer. The drive gear is a X shaped gear.
    also check the M toner supply clutch
    in rear
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Teckat is wright.Check your serial number!
      Affected Machines:
      IR ADV C5030 TW 120V EUY00505 and later IR ADV C5030 230V ETG10171 and later
      IR ADV C5030 UL 120V GNG12194 and later IR ADV C5030 AU 230V ETM00593 and later
      IR ADV C5035 TW 120V EUU00514 and later IR ADV C5030 EUR 230V GNH10643 and later
      IR ADV C5035 UL 120V GNW10952 and later IR ADV C5030I EUR 230V GNM14470 and later
      IR ADV C5045 TW 120V EUP00507 and later IR ADV C5035 230V EEA10241 and later
      IR ADV C5045 UL 120V GPQ11432 and later IR ADV C5035 AU 230V EET00637 and later
      IR ADV C5051 TW 120V EUJ00505 and later IR ADV C5035 EUR 230V GNX10290 and later
      IR ADV C5051 UL 120V GQM11889 and later IR ADV C5035I EUR 230V GNY12226 and later
      IR ADV C5030 CN 220V EUW00503 and later IR ADV C5045 230V EBU10209 and later
      IR ADV C5030 KR 220V EUX10011 and later IR ADV C5045 AU 230V EBV00654 and later
      IR ADV C5035 CN 220V EUR00503 and later IR ADV C5045 EUR 230V GPU10228 and later
      IR ADV C5035 KR 220V EUS10008 and later IR ADV C5045I EUR 230V GPV11271 and later
      IR ADV C5045 CN 220V EUL00504 and later IR ADV C5051 230V DZS10109 and later
      IR ADV C5045 KR 220V EUN10003 and later IR ADV C5051 AU 230V DZT00637 and later
      IR ADV C5051 CN 220V EUG00503 and later IR ADV C5051 EUR 230V GQN10175 and later
      IR ADV C5051 KR 220V EUH10011 and later IR ADV C5051I EUR 230V GQP10745 and later
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Also, something even simpler, have you cleaned the laser slit glass for that color using the blue wand? Pull the waste toner bottle out of the way and swab all 4 of the slits...
        • macuk
          • May 2009
          • 90
          thanks for that guys, am going back to customer on Tuesday morning and will check the x gear and clutch. Thanks for the input mrfixit51, but as fault disappeared for a short while after stirring, i don't see why it would be the slit glass. However i appreciate the reminder about cleaning the laser slit glasses. Also on a run, the deletion got worse.
          • macuk
            • May 2009
            • 90
            Firstly, I would like to apologise. the machine was a irCADV 7055i.
            Had to replaced the magenta developer assembly due to lack of dev.
            New unit had twice as much dev in it than the old unit.
            The original unit had a count of 79K. only 14% of life.
            Thank you for your help and advice.
            • vigour
              • Aug 2010
              • 1038
              They sent out a bulletin with reminders,trying to blame us for premature 7055 dev replacements, assuming that we are not following the instructions to keep the tape on the gears until the foam is removed, and also turning the roller in the wrong direction,
              It is easy to take the top cover off (2 screws) and also the blade(2 screws).
              Sometimes that gummy mylar guide gets ripped and stuck on the inside of dev, causing blank areas.
              • zoraldinho
                • Mar 2008
                • 5015
                Very interesting.I have this issue on IRA 0960 and two IRA 7055.Only magenta developer can't make over 150K.Canon have some bulletins for this issue,but
                no help.
                • zoraldinho
                  • Mar 2008
                  • 5015
                  [Notes when handling the developing assembly of four colors]
                  a. Manual reverse rotation of the sleeve is not allowed.
                  b.Manual normal rotation of the sleeve should be one to one and a half turns.
                  c. Initialization of the included developing assembly is not allowed when installing the copier.
                  d. Initialization of the once used developing assembly is not allowed.
                  e. Initialization is allowed at the time of replacement with the new developing assembly.
