iRC 5185
  • Apach
    • 157
    [Error Code] iRC 5185
    Hello,
    Today iRC5185 display code E000009-0500 adn very hard noise like broken gear inside.
    If someone can give me parts number for fuser and gears. Tnx
    There is no stupid question, just stupid answer
  • teckat
    • 16083
    Originally posted by Apach
    Hello,
    This pub has all the info u need/
    remember if your unit is old/ easier ti replace with a re-furb unit
    • Apach
      • 157
      tnx
      • Apach
        • 157
        Im replacing fixing unith with one from another maschine. I check all gear and mechanical is OK. Now I have only displayed error code E000009-0500. Before I try to change all sensors please tell me your advise what is posibly wrong. How cost newfixing unit in USA ?
        • teckat
          • 16083
          Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the fixing (pressure) belt.
          because u swapped units u need to go in service mode and run this function below
          COPIER > FUNCTION > FIXNG > FX-UHP-S > FX-LHP-S
          u highlight/select>FX-UHP-S hit OK to run- /then highlight/select>FX-LHP-S hit OK to run
          this is what u do when u put in a new unit
          new unit is over $1,000.00 US
          • Apach
            • 157
            Problems is when I turn ON and machine start checking then just before allow display give me that code and I heard cca 10 times short sound(beep). Im not posibile to see display menu. Atm Im must wait cca 10 days for new one (1300 euro). Im suspect on some small problems inside fixing unit or maybe in drive unit next to fixing unit. If u have some idea please tell me. Conectors and cabels is OK.
            Another thing. From prospect fixing unit part number is FM2-7472 but our Canon give me FM3-3779. What differents betwen two models?
            • vigour
              • Aug 2010
              • 1038
              Clear error in service mode ,with door open first
              • teckat
                • 16083
                E009 = ERR CLR not listed as a clear function/
                • Apach
                  • 157
                  In service mode I clean error code and FX-LHP-S return NG! I try with old fixing unit (lower belt blocked but now is ok) but result is same error code. Please if posibile to send me pub No. TP09 179a.pdf and TP07 208.pdf
                  • teckat
                    • 16083
                    plenty of reading on E007
                    TP07 208=TP07.pdf
                    E007 TP07-1.pdf
                    TP09 179a=TP09.pdf
                    iR5185 Fuser Update.pdf
                    • vigour
                      • Aug 2010
                      • 1038
                      MY Bad
                      • vigour
                        • Aug 2010
                        • 1038
                        FM3-3779 is the complete unit, forget about the other number.
                        Read page 2 of the first document Teckat sent you.
                        Clean or replace the connector on the machine side.
                        Just looking at at will not help
                        • Apach
                          • 157
                          Please can you give me part number for Fixing preassure release HP sensor ? I try to change that sensor. If dont work then I replace hole fixing and driver unit
                          Problem in Croatia is we dont have technician man wich knowlege for that device
                          • teckat
                            • 16083
                            PS46-FH7-7312-000/fixing pressure release HP sensor
                            E009-0500/E009-0501/E009-0502 occurs when machine is running: Pressure release gear positioning plate comes off/ Pressure release drive gear is damaged/Pressure release sensor is faulty.
                            Description
                            After replacement of the fixing assembly, this machine indicated the error code "E009-0500", "E009-0501", or "E009-0502" during operation. These error codes may be displayed due to a fault in the fixing pressure motor, the DC Controller PCB 2 (MAICY), or other. However, before replacing these parts, perform the following field remedy.
                            - E009-0500 can be displayed when the pressure belt unit pressure release HP search error occurs.
                            - E009-0501 can be displayed when the pressure belt unit pressure release timeout error occurs.
                            - E009-0502 can be displayed when the pressure belt unit pressure timeout error occurs.
                            In this inspection, loosening of the pressure release gear positioning plate, damage to the pressure release drive gear, and a fault in the fixing pressure release HP sensor (PS46) are conceivable.
                            1. Check if the pressure release gear positioning plate [1] comes off; if so, re-fit it as shown in
                            2.Detach the plate [3] to which the 50T gear is mounted, and the compression spring [4], and then check to see if the 17T gear [5] (Pressure release drive gear) is damaged. If damaged, replace the 17T gear by a new one.
                            3. Check if the fixing pressure release HP sensor (PS46) [6] is damaged; if so, replace the sensor with a new one by referring to "Procedure for Detaching the
                            Fixing Pressure Release HP Sensor (PS46)."
                            Note: When mounting the pressure release sensor mount [7], fit it by pushing it in the direction of the red allow (I.e., downward).
                            • Apach
                              • 157
                              One more Q. On this picture that part OK or not?
