canon ir 2030
  • Saji
    • May 2010
    • 97
    canon ir 2030
    Canon ir 2030 was giving e-007, we replaced fuser film, after fixing the unit, machine shows paper jam signal, we checked all sensors/ activators, cleaned the sensors , but prob stil persistes, any help will be appreciated, thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    try CLEAR ENGINE
    • Saji
      • May 2010
      • 97
      Thank you..can you plz.tell me.how to clear the engine as suggested by you.it will be a great help.thanks`
      • zoraldinho
        • Mar 2008
        • 4999
        In service mode under CLEAR.
        • Saji
          • May 2010
          • 97
          Thanks, this what i did...service mode..SSW1 change bit 1 to 0 as directed in manual..but same..i will change sensors and check..thanks again.
          • teckat
            • 16083
            Make sure fixing film unit's green jam release lever is installed on unit & working
