C3220 blurred image when printing but not copying
  • repeatcopiers
    • Sep 2008
    • 591
    I have a C3220 in the field that is giving a double image when printing a document from the computer, but copy is perfect when making a copy from glass or feeder. It is also leaving some color toner on a b/w image when printing only. This is happening from every computer in the office. Any ideas?
  • teckat
    • 16083
    Print out the P PRINT settings/
    in service mode do a DCON CLEAR/
    power off/on
    re-input DCON settings
    also remove ITB/ REMOVE the metal plates clean underside/
    Just a note ***I throw away the large plate/ it becomes bent & causes smears on image/make sure to ground other side of varistor under metal leaf plate{as shown}
    • repeatcopiers
      • Sep 2008
      • 591
      Thanks for this information. The customer had their page setup defaulting to Color instead of B/W, when they changed that, everything cleared up.
      • sgcopiertech
        @Teckat: you mean keep the small plate & varistor only?
        @repeatcopiers: it is advisable that you service the ITB since the image is blurred when printing color documents, it practically means it would also produce blurred "photocopy" results when photocopying color.
        • teckat
          • 16083
          we remove that large plate on all iR5180 series & iR3200 series machines/
          even on the ITB retrofitted ones that Canon came out with on the 5185
          u keep that small plate & varistor connected / just retro fit the other end of varistor under that side metal leaf spring/ see pic above
          anyone who services these machine that have high volume , u will see the scrape marks it produces on prints & toner build up underside of plate.
          • repeatcopiers
            • Sep 2008
            • 591
            Of course color issue returned, so tech did what you suggested above and now they have great color copies too.....thanks again for all your help!
            • teckat
              • 16083
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Just to add a tip.. If the varistor is not added to the ITB assy, it will cause electrical issues. E-code like E0003-xxxx can pop.
                But the technique works like a charm.
                • teckat
                  • 16083
                  Thanks,SCREWTAPE- you are dead on the money/
                  Varistor is a must/
                  I hook loose end up under leaf spring
