Error E000000-000003 in ir5000 - 6000
  • kissyxerox
    • May 2025
    I am having Ir 6000 Some times my machine shows this error E000000-000003. When it appers on the display, I go to *28* and clear all the error. then my machine will start running. please help me to correct this problem. from which side this error code problem
    • 22930
    Fuser
    Fuser problem. Lots of possibilities:
    open thermistors, open fuser lamps, open thermal switches. Check these first. If you can't identify these parts get a Canon tech to help.
    • hanna
      if you can reset the error then it's extremely unlikely there is anything wrong with the lamps or the thermal switches (if they are blown, they stay blown and resetting the error won't help). it is highly likely you have bad thermistors.
      • montana
        • Aug 2008
        • 393
        hi .first enter the service mode & clear the error if it doesn't work then you can try to replace the fixing unit .may be the electric main source not stable try to use current stabiliuzer device.
        i wish good luck my dear
