IR1023N with Windows 7
  • Brian8506
    • 1665
    Does anyone know if there is a user disc for this. I am able to set up to print but when trying to set up to scan using original disc, computer tells me its not compatible. Searched knowledgebase and grid as well as customer site and download center but cant find anything. Its connected via usb
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    What kind of scanning you try to install.
    • Brian8506
      • 1665
      The machine comes with the install disc for print, scan, toolbox, and online manuals. I believe it uses OCR. There is no network adapter in the machine. It's connected by USB. Customer was all set up on XP and when they upgraded to 7 the original disc is incompatible.
      • teckat
        • 16083
        Check the orig.CD /re-load drivers Vista & XP
        did u see this quote>>
        Scanning with Windows 7
        -1023 series
        Go to run and type secpol.msc - Expand Local Policies>Security Options - Network security needs to be : LAN Manager authentication level : Send LM & NTLM responses. and Minimum session security for NTLM SSP : disable require 128-bit encryption
        • Brian8506
          • 1665
          I did see that and was going to try that tomorrow or Monday
          • costd
            • Jan 2008
            • 409
            I am often wrong, but as I recall, Canon has not (and does not plan to) produced a Windows 7 version of Toolbox (as in uses USB).
            I know you said it did not have a network adapter, but that is what the N part of iR1023N stands for. As I think I understand it:
            1023 = no DADF, no network
            1023N = adds DADF and network printing.
            1023iF = As above plus fax and universal send.
            • Brian8506
              • 1665
              It has usb and a dadf. I could swear it was an n model. I'll find out tomorrow. I know they didnt get the optional network adapter.
              • linuxxpwin
                • May 2008
                • 205
                Are you absolutely sure 1023N does not have a Network adapter? the model number given Suggest otherwise.
                • teckat
                  • 16083
                  1023_series_brochure.pdf
