Error code on Image Runner C5180
  • cfltech
    • Aug 2009
    • 13
    [Error Code] Error code on Image Runner C5180
    I am having an error code E020-0081 on this machine.
    Has anyone replaced the SALT sensor on this machine? or will replacing the
    yellow drum suffice?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Print PG 10 and check visuall quality.
    Check drum life in service mode.
    Usually is drum.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      If you have been in the ITB area before this occurred, make sure the sensor assembly is seated properly in it's supports. I shot myself in the foot once, had the rear pivot not fully seated, and it popped codes on me shortly afterwards...
      • cfltech
        • Aug 2009
        • 13
        Thanks for the responses.
        Will follow up
