Canon GP285
  • grefor
    • Aug 2025
    Canon GP285
    Hello,
    How can i change the pick mode of the DADF of canon gp285 from botom pick up mode to top pick up mode,
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Originally posted by grefor
    Hello,
    dadf-a1-sm.pdf
    • grefor
      I found service mode>copier>option>body>user facedown, changing 0 and 1 but no effect
      • Brian8506
        • 1666
        Not sure which model that crosses over to in US but if its similar to IR 330/400 and you have a finisher attached, you can't change it.
        • grefor
          I powered on/off tha machine of course.
          I will try to disconnect the finisher later to see if this help.
          It's doing top pick up now and the belts slip thats why i want to change.
          • Brian8506
            • 1666
            If you disconnect finisher it will change top to bottom. As soon as you reconnect, it will revert back to top feed.
