Image Problem
  • andalasgt
    • Oct 2010
    • 49
    Image Problem
    how to solve the problem of the copy image like this ....
    Thanks For you All...
  • andalasgt
    • Oct 2010
    • 49
    Machine is Ir5000
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Do you made periodic service end new corona wires?
      • andalasgt
        • Oct 2010
        • 49
        I have changed corona. It chapped after polishing drum.
        • zoraldinho
          • Mar 2008
          • 5015
          Probably you didn't clean enough drum surface.You stil have some powder on it???
          • andalasgt
            • Oct 2010
            • 49
            Thanks for replies. The problem still remain although have tried hundred of copies.
            Is it OK if I polish drum again?....
            • zoraldinho
              • Mar 2008
              • 5015
              Moisten lint-free paper [1] with 5 to 10 cc of alcohol [2]; then, collect 0.2 to 0.3 g of drum cleaning powder (CK-0429) [3] with the lint-free paper
              While forcing the lint-free paper against the photosensitive drum, wipe it as if to rub it from the front to the rear and then from the rear to the front.
              Rub it over a width of 5 to 10 cm in drum peripheral direction.
              - The drum life is not likely to be affected if the back-and-forth strokes of the lint-free paper over a single area is limited to 15 to 20 times
              When alcohol has evaporated, dry wipe the surface with lint-free paper. If the surface cleaned with the lint-free paper is uneven, go back to step 4), and repeat
              the work by increasing the number of back-and-forth stokes.
              Rotate the drum an equivalent of the width over which its surface has been cleaned, and repeat steps 3) through 5) until the entire surface of the drum has been
              cleaned.
              • andalasgt
                • Oct 2010
                • 49
                Thank you, I will re-polish it tomorrow...
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Why did you polish the drum in the first place?
                  • kucinggarong
                    Re: Image Problem
                    judging from ur location u r in indonesia. I was station there long time ago. I used to use "Sanpoly"
                    on a soft dry cloth, clean one. Just wipe the drum smoothly until it shine again, remember not to hard cuz it could scratch ur drum
                    • Dedy.P
                      • 67
                      Re: Image Problem
                      it's ok, just don't drop it
                      • charm5496
                        • 2387
                        Re: Image Problem
                        problem was from 2 months ago...we are replying because????
                        • andalasgt
                          • Oct 2010
                          • 49
                          Re: Image Problem
                          Thank you for you all benefit comments. The problem was solved about 2 months ago ....
                          I am sorry not to inform you all. It's because the drum not quite warm yet.
                          • gensys
                            • Jan 2011
                            • 323
                            Re: Image Problem
                            How many copies the mashine has made?
                            The Road will be Mastered by >>> the Going...
                            • andalasgt
                              • Oct 2010
                              • 49
                              Re: Image Problem
                              2.241.483
