how to change the fuser on Canon Imagerunner C3200
  • Hamid
    • Jul 2025
    [Jamming] how to change the fuser on Canon Imagerunner C3200
    I am going to work for the first time on Canon Imagerunner C3200, could somebody tell me how to change the fuser assy.
  • charm5496
    • 2387
    If you are just swapping the assembly it is two screws holding the fuser in one in the front and one in the back. Always check the NIP pressure when installing a new fixing unit.
    • Hamid
      I am sorry, i don't want to be a pain, but how to check the NIP pressure.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Enter service mode, and navigate to copier>function>fuser>nip-chk
        <FIXING>
        Automatically adjusts fixing unit.
        NIP-CHK
        Fixing nip width automatic measurement output.
        Operation 1) If the finisher is connected, remove it from the copier and pull out the
        method lattice cable.
        2) Place A4 (LTR) size paper in the manual feed tray.
        3) Press the OK key (the paper in the manual feed tray is fed).
        4) When the fed paper is pressed by the fixing roller, it stops, and is delivered
        about 15 seconds later.
        5) Check that the nip width of the delivered paper is the standard value.
        F05-701-02
        6) If the standard value isn’t met, adjust the value. See the Printer Manual,
        Chapter 6, “Fixing System”, 4. “Disassembly and assembly”, 4.2 “After
        fixing unit disassembly”.
        7) After completing the operation, output a test print
        (COPIER>TEST>PG>TYPE (6): Grid).
        Remark The paper is delivered from the side paper delivery tray.
        • charm5496
          • 2387
          What mrfixit said is spot on. Thanks for the assist!!!
          • mrfixit51
            • Oct 2008
            • 1975
            You are welcome my friend!!
            • teckat
              • 16083
              Don't forget to remove/disable the finisher from machine-before nip check
              & make sure to put on the green pressure release handle
              note> old handles will not fit on new models
