iR c5185i print function missing or disabled?
  • butitsmyfirstday
    • Feb 2011
    • 60
    This machine throws no error codes and will pass paper but nothing prints, pages just come out blank. Mechanicaly everything looks/checks out fine. Checked to verify all boards were present and seated correctly, I found that someone had pinched the fm2-6810 control board so I borrowed one from another machine but still no printer, clearly I am missing something somewhere but I'll be darned if I know what it is...any help would be great thanks in advance for your time....
  • SCREWTAPE
    East Coast Imaging
    • 3371
    What driver are using?
    Are you famillar with service mode on this device?
    • butitsmyfirstday
      • Feb 2011
      • 60
      Hi screwtape thanks for responding, it's not on a network so no drivers yet...I believe the installed firmware is 92.06....I'm still really new to these machines but I'm finally getting comfortable with service mode levels 1 & 2...
      • butitsmyfirstday
        • Feb 2011
        • 60
        It's acting like there is an open I/F PCB for the H1 installed...interface is set to 0
        • teckat
          • 16076
          the slot will hold either the IF PCB for Fiery or Multi-PDL KIT Pcb.
          did u check the slot in back ???
          if copies and prints & test prints are BLANK with no error codes
          Try re-flashing the machine , if it doesn't resolve the issue, suspect a faulty DC Controller
          • vigour
            • Aug 2010
            • 1038
            just for clarity,
            1 does it make blank COPIES too
            2 is there a small happy face in one corner when you PRINT from computer .
            3 is it blank if you make a PPrint or test page PG5
            • teckat
              • 16076
              imageRUNNER C5185 / C5180 / C4580 / C4080 / C5185i / C5180i / C4580i / C4080i Blank
              Solution :
              All prints from the machine come out BLANK.
              Go in to service mode in level 2 under COPIER > DISPLAY > DPOT check that 1TR-DC-Y/M/C/K are all at 0 which means that there is no Primary Transfer on all 4 colors. All the other keys such as CHG (Primary Charge) and 2TR (Secondary Transfer) show voltages. This would point to a HVT problem. Before suspecting an expensive board, check the transfer lever in the front of the machine. If the ITB is not fully engaged, this can occur. See the picture below:
              • butitsmyfirstday
                • Feb 2011
                • 60
                @vigour
                1 off the glass is blank
                2 not connected to network
                3 Pprint & test page PG5 blank
                • butitsmyfirstday
                  • Feb 2011
                  • 60
                  @teckat
                  1. the slot is occupied by a Multi-PDL KIT Pcb
                  2. COPIER > DISPLAY > DPOT all voltages are zero
                  3. Transfer handle is intact and transfer assembly appears to be fully engaged
                  I had a little time this afternoon as well as quite a few donor machines so I went ahead and swapped out all the controller boards then re-flashed there was no change...
                  • SCREWTAPE
                    East Coast Imaging
                    • 3371
                    If you look at the right side where the bypass is at . There is a panel with a yellow caution sticker. It has one screw. Remove it. You should be able to see the belt. Check if images are being transfer to the belt from the drums. Make PG10 test prints from service mode. As the image formation process occurs look the ITB belt. Could be the HVT. How does the error history look like. Are there any Error codes from the past?
                    • butitsmyfirstday
                      • Feb 2011
                      • 60
                      Hey screwtape...unfortunately this is a lease return and in addition to pinching a few parts some one cleared the history...nothing transfers to the belt...not even the registration when it is first started...
                      • teckat
                        • 16076
                        @teckat
                        U could have a bad or damaged/disfunctional SRAM PCB
                        If you pull out the SRAM PCB from machine B and mount it to machine A,the PCB will be initialized and be rendered useless for machine A or B. Take full care.
                        someone may have done this without knowing/ funny thing is it will not pop an ERROR code-
                        a bad SRAM PCB board can cause Blank copy issue
                        Stupid question ??
                        Are the DRUMS TURNING ????
                        COPIER > DISPLAY > DPOT check that 1TR-DC-Y/M/C/K are =
                        all at "0" which means that there is no Primary Transfer on all 4 colors.
                        This is Probably an HVT 2 issue/
                        Why there is no error code that pertains to the ITB not displaying the patches on power up is a mystery-
                        • butitsmyfirstday
                          • Feb 2011
                          • 60
                          You know, I have no idea if the drums are turning... I'll have to check them out in the morning...I wonder if maybe someone dug into this machine to swipe something in addition to the one I saw...
                          • teckat
                            • 16076
                            If in any doubt , if near>call this Company below
                            LDI LA
                            6704 Valjean Avenue
                            Van Nuys, CA 91406
                            Tel: 818.781.8110
                            Fax: 818.787.5470
                            Hours of Operation:
                            8:00 am to 5:00 pm PST
                            • butitsmyfirstday
                              • Feb 2011
                              • 60
                              I'm about 5 miles from them...if someone grabbed something from the hvt circuit wouldn't it throw an error?
