In iR 5065 machine I am facing a problem of paper jam,it is working in single mode but in multicopy mode the papers are going towards the duplex unit and jammed.Customer is using 70 gsm papers. even in print a single paper diverted towards the duplex.Please help.
Paper jam at fixing unit
Can you post eny jam code?Practice makes perfect
If you want something done right, you have to do it yourself
Do you fimillar with service mode?Practice makes perfect
Check in SM
COPIER>DISPLAY>JAMPractice makes perfect
