NP6035, PCQ issue,smudges
  • rdyjnkns
    • 135
    I'm working on a NP6035 that produces smudges and faint echoes. I have replaced the drum unit and transfer roller, and cleaned the paper transport path and fixing assembly. I cheated the main door switch and can see where the issue is being generated, at the developer and drum. Could this be a toner problem?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    If you using non OEM toner,YES.Post a pic.
    • rdyjnkns
      • 135
      NP6035 smudges
      Here is the image of the test shot. Hopefully this will help. Thanks to all.
        • 16083
        if those smudges don't move or change in size on continuous copies>>>
        Remove>check & clean blank exposure assembly
        If u replace DEV UNIT-remember to------
        Initialize the Idle Rotation Mode using the *4* function in the Service Mode by selecting BK-ROT and pressing the OK Key. The display will change from 0 to 1 for the Idle Rotation This will last about six (6) minutes.
        Increase PRIMARY in Service Mode *3* to + 3 more than the value given on the Drum Label. Next, adjust the BIAS to normalize the image. Initialize the Idle Rotation Mode
        (BK-ROT) again.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          in my opinion KATUNE is better brand of parts ..me l try many drum unity ...
          BEST TECHNICIAN . NICE PEOPLE .
            • 22997
            Agreed. Use OEM toner only. =^..^=
            • Borsody75
              • Mar 2011
              • 83
              This must be a toner fault.
              I have seen similar images when the consumer used sharp toner into Canon.
              On the other hand any type of toner could also be wrong after staying long time in a magnetic field (for example near a big speaker)
              If I were you, I would hoover the hopper assy and the developer assy, then fill up with the new reliable toner.
              Don't forget initialize the new toner as Teckat mentioned above.
              • logonjim
                • 136
                I would make sure blank exposure lamps are clean .This used to happen a lot on NP6330.Take them out and clean all.
