E000000-0001 ir3045
  • mrjobusa
    • Apr 2006
    • 14
    [Error Code] E000000-0001 ir3045
    Book Suggest Dc controller, could it be the fixing unit?
  • teckat
    • 16083
    did u try to clear error in service mode ?
    how are the door switches ??
    did u check the fuser ??
    • mrjobusa
      • Apr 2006
      • 14
      Clear Error. it came into ready as soon as you select cassette or try to print, the error code
      • mrjobusa
        • Apr 2006
        • 14
        i'm thinking along the same line.
        • dhanesh
          • Jun 2010
          • 63
          Hey replace the fixing thermistor yaar
          DHANESH
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Did you try cold beer?
            • Borsody75
              • Mar 2011
              • 83
              You can measure the ceramic heaters via the 3 pole white connector. If you can't measure resistance on any of 3 pole, the heater is wrong.
              • mrjobusa
                • Apr 2006
                • 14
                it was time for a new fixing unit. it solve the problem. Thanks to everyone for their input.
