canon 3380 e000747-3906 code
  • TEKK09
    • 142
    Could someone tell me what this code is, and if I need to take parts? I don't have a manual for this model. Thanks!
  • TEKK09
    • 142
    That's a C3380 if it makes any difference.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Main controller PCB error (Image processing ASIC or memory control/communication control ASIC)
      Disconnect and connect the main controller PCB or replace it.
      • teckat
        • 16083
        before u replace any boards
        Look at this PDF/ u may need to remove and re-seat all sub-pcb's
        TP07.pdf
        When poor/dirty or miss-aligned contact develops between one of the Sub PCBs and the Main Controller PCB , various kinds of error codes below or malfunction to the machine may occur.
        E747/E748/E240/E241/E350/E351/E732/E733/
        this is the first step in troubleshooting on all PCB's before replacing them
        • anothertech
          • 1771
          Here's another possibility,
          Error :
          Error code E747-3906 only after trying to print from Microsoft Excel and/or printing from a Mac.
          Workaround :
          One of the two PDRM- EF-A PCB's is bad. Replace board. The part number is FM2-9166-000.
          • TEKK09
            • 142
            Thank you for the great response! Now I have a good idea about how to fix. Have a great day.
            • zoraldinho
              • Mar 2008
              • 5018
              • TEKK09
                • 142
                I fixed the problem just by cleaning the edge connections on the sub boards. Did not have to replace any parts. And now it's been a couple weeks and they haven't called back. Thanks so much for all the help.
