Usb to paralel cable
  • Dedy.P
    • 67
    DEAR ALL
    I want to ask you guys what cable do i use to replace LPT cable, that working for downloading from SST.
    i want to buy a ATEN USB TO PARALEL UC1284B, will it work for downloading to iR5000 ?
  • The Watchman
    I use the Canon issued Nethawk cable.
    Even though it's an official part, you have to jump through some hoops to get it to work.
    • Dedy.P
      • 67
      so, will it work?
      • ymmtech
        • Jun 2009
        • 190
        I use a cheap second hand notebook equipped with parallel port as an sub to nethawk. Using SST 1XX on windows98. Ya, parallel port run at high speed mode. And if need to use network cable will just boot up windows XP. The note book is configured to dual boot. While the windows XP have sst 4xx installed.
        • Dedy.P
          • 67
          can you explain to me what is " jump through some hoops to get it to work"
          • Dedy.P
            • 67
            i agree with you, but my PC don't have parallel port, and it's running on win 7, which is doesn't support parallel port anymore.
            • ymmtech
              • Jun 2009
              • 190
              These what i can think of. Choose either one.
              1.Buy a nethawk.
              2.Buy a second hand note book with parallel port, it cost only fractions of nethawk.
              3.See if your friends can make a uc1284b to nethawk simulation? OK, don't take as real.
              4.Use disk cloning tools if u re not intended to do any firmware upgrade, backup RAM data, etc.
              • Dedy.P
                • 67
                thank you, but i don't know where i should buy a nethawk.
                • ymmtech
                  • Jun 2009
                  • 190
                  Neither do i, so 3 choice left.
                  • CanonSco
                    Man About Town
                    • Jul 2010
                    • 368
                    I use a nethawk.
                    Although it will now be a couple of years since I used it in anger.
                    BUT - cant you just buy a $10 USB to Parallel adaptor and use a normal bi-centronix cable as before?
                    Yes, I am a nerd.
                    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
                    • teckat
                      • 16083
                      no
                      • Dedy.P
                        • 67
                        Originally posted by CanonSco
                        I use a nethawk.
                        i already try that, but it's not workin, is there any additional setting?
                        • charm5496
                          • 2387
                          store bought USB-parallel cable will not work for SST. If you are running win 7 you have to buy the new style cable which is around $120 or so. It will auto load and configure the driver for you when you connect.
                          The old style needs to be manually configured and loaded.
                          • Dedy.P
                            • 67
                            will this ATEN USB TO PARALEL UC1284B cable support it? it's support win 7.
                            and only cost about $20, do you have any suggestion about the cable?
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              I tried the PCMCIA parallel port card some time ago, under XP.
                              I must have tried at least 7 or 8 different parallel cables. While they all worked for printing, not one worked for updating firmware.
                              No banana with the USB to parallel converter, either.
                              You just need to bite the bullet and get the correct Nethawk cable.
