Usb to paralel cable
  • Dedy.P
    • 67
    #16
    Originally posted by KenB
    I tried the PCMCIA parallel port card some time ago, under XP.
    I must have tried at least 7 or 8 different parallel cables. While they all worked for printing, not one worked for updating firmware.
    No banana with the USB to parallel converter, either.
    You just need to bite the bullet and get the correct Nethawk cable.
    Thanks for the info you got.
    • charm5496
      • 2387
      #17
      here is the new number FY9-4368-000. Dealer cost is $188 so if you have to purchase from someone else hold on to your shorts!!!!
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        #18
        With the stated price given as $188, ym's suggestion of finding an old laptop, they are very easy to find, is the less costly solution. NO other USB to Parallel cable will work,,, period...
        • vigour
          • Aug 2010
          • 1038
          #19
          here is your chance, this is your lucky day
          http://www.copytechnet.com/forums/ca...thawk-usb.html
          • Dedy.P
            • 67
            #20
            thank you for all you guys help, wich one is faster for downloading, nethawk usb or parallel cable?
            • teckat
              • 16083
              #21
              USB
