Ir 4570 pick up the paper slow from a4 trays????
READ>>>>>>>>>>>iR4570 Jam Codes 0205-0207-0105-0107-0108TP06.pdf
This is what u Posted > in Black Print> Manual description in RED
1.jam type: Delay. sensor: Ps9c=pre-registration sensor detects paper before registration
2.jam typr : Delay . Sensor : Ps1c=cassette 1 paper sensor detects the presence/absence of cassette 1
3.jam type : Delay. Sensor: Ps13=fixing outlet sensor detects paper at the fixing outlet ,PS14=No. 1 delivery sensor detects delivery
4.Jam Type : STNRY. Sesnor : Ps3a=cassette 1 paper level sensor A detects paper level A in cassette 1
JAMS.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I have to agree with Teckat, please just post the jam codes, not the explanation of the jam codes...
And you say you checked the sensor finger,, does it have the metal shield on it? And if it does not, replace it with one that does have the shield. FL2-4520-000"Once a King, always a King, but once a Knight is enough!"
READ>>>>>>>>>>>[ATTACH]9897[/ATTACH]
[ATTACH=CONFIG]9896[/ATTACH]
thank you..
i can post the jam codes again...Comment
I think helping this guy just a waste of time.
He is just kidding us.
In my opinion Seshu isn't a technician, and never had copymachine.
When I asked him:
Have you checked the blue drum protector cover?
Said:Yes...
...but this machine hasn't got blue drum protector cover...Comment
When I asked him:
Said:Yes...
...but this machine hasn't got blue drum protector cover...If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
2011-05-18 21.45.04.jpg2011-05-18 21.43.38.jpgTeckat ....
now post jam code screens in mechine......
every code repeated.... so same place jammed the paper....
2011-05-18 21.50.36.jpgComment
At last replace pick up rollers!If it ain't broke, don't fix it
Originally posted by Canon.TechCan you please post a picture of the cassette feed units & the lower right door? this will help us a lot.
CASST 1.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: Ir 4570 pick up the paper slow from a4 trays????
i can post mytray images..
2011-07-29 22.24.23.jpg 2011-07-29 22.23.37.jpg2011-07-29 21.50.37.jpgComment
Yes, without delay, so we can put this thread to bed...
The new style parts completely eliminated the original design problems with that area. New style door, inner guide, grey vertical rollers, they are all needed to fix your problems..."Once a King, always a King, but once a Knight is enough!"
