How to slove Canon iR C3200 print blur ?
jamesgraves
Re: How to slove Canon iR C3200 print blur ?
Are you saying that it's impossible for me to get the information from the machineComment
Dear all,
I have problem with my Canon iR C3200, it working on well till I printed 3,000 pages. Now it's printed very blur, I tried to clean the rollers in side transfer belt but nothing change. Plz help me to solve this problem ?? I post the image good and the image with my iR C3200 problem. Thank you,
[ATTACH=CONFIG]9847[/ATTACH]
[ATTACH=CONFIG]9846[/ATTACH]
I think you have to change them but first make e PG10 and post here ."Who loves the roses,must also bear thumbs"Comment
when did I say it was impossible ??
i am saying if u do a DCon clear and u have no P PRINT with settings to load back in > u will have issues trying to figure out what to put back in/
Dcon clear puts printer into standard Factory settings---most of these printers are missing their original personal factory set up sheet-
if u select COPIER > FUNCTION > MISC-P > P-PRINT to print out the
service mode setting values / it should list your currant settings/ have never seen a P PRINT with missing settings
if u select COPIER > FUNCTION > MISC-P > LBL-PRNT > it Prints out a blank service label where u can write down settings in Printer-
USER-PRT= Prints user mode list.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
jamesgraves
Canon imagerunner c3220 and a c3200
My canon c3220 the image just started printing very light as if the transfer belt was not transferring all of the toner to the sheet.
My canon c3200 would restart in the middle of the run and the panel would go out
Does anyone have any answersComment
Re: Canon imagerunner c3220 and a c3200
Many factors can cause light image/or partial light images---
u are all over the place !!!!/ first u talk about Dcon/ & missing P Print settings> now u talk about very light image, and printer re-start/& panel issues
1-On Control LCD Panel & Printer Re-Start Issues > u first need to power off/unplug printer -remove the Memory>clean ends >re-seat them/ also remove Boot Rom and do the same routine
2-Now on the light image issue> first test to remove the small cover over the ITB Unit, so u can view the image process/ set up printer to print a PG10 test print > look into where u see ITB turning, see if the test print PG10 stripes are on ITB sheet during rotation> (Check all colors as they rotate on sheet) if they look good on sheet and are poorly transferred (light/faint) on paper>look at that Secondary Transfer
Internal Roller (inside ITB UNIT) & on External Secondary Transfer Roller, make sure it is sitting correct & rolls smoothly
3-If the PG10 looks very light on ITB before transfer to paper> suspect the Primary Transfer rollers (inside ITB UNIT)/ or the Pattern Reader Unit
(check it's position)
pattern read unit.JPG make sure it is secure on ends/ and in down position**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
PhillHoang
Hammer time is right.
the sample looks missing the cyan.when you do the auto gradation,the test came out not alignining.
Clean the idle rollers with alcohol;dry clean the primary rollers and ITB belt,pay attention on the cyan roller.
make sure the 2nd transfer roller in charge (broken mechanism).
run test in the service mode for the gridtest,make sure all colors line up.If not,you can reset the laser home position;
reset DCON or even manufacture setting.Comment
