I tried to clean everything, but the image printed out still blurry, nothing to be better. @Tekat maybe i have to change the brand new Transfer Belt ?
How to slove Canon iR C3200 print blur ?
Hold on> u posted two prints /
Top one shows poor Primary Transfer/ Pic below that one looks OK!!
If u think Top pic is a blurry issue/ that is a poor description //
go in service mode /print out two PG10 Prints/ and post them**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
yes, I did, tried to print PG10, but the printer does not print event PG6 or something. im using this iR C3200 without fiery.
I have 5 canon iR C3200/3220 copiers. when I changed the transfer belt from the machine working on well to this one, the image printed out still blurry and else .Comment
If you swapped ITB assemblies and you still have the same misalignment going on then the problem is pointing towards the ITB drive assembly which could have worn or dirty gears on it or your laser units need to be retimed to bring everything back into alignement.Accidents don't just happen. They must be carelessly planned.Comment
His picture shows an itb unit with no belt, and coloured primary transfer rollers.
His picture looks like weak image to me, not blurry.Comment
yes, so sweat to use Canon iR C3200, there are a lot of troubleshot, i used to print PG10 before but right it can not print out. the colors are misalignment even i tried to clean every thing like you guide. maybe I need to clean the laser ? I afraid I can not re-seat the lasers to the old position after i take them out.Comment
I swap whole the ITB unit from other machine which's working on well to this one, not swapping the belt only @Vigour.Comment
Did you read the attachments Teckat and LindaOwen sent you.Comment
do you have paper in your cassettes and registered correctly for size and type for the test page to pull from?
Choose test print hit <OK>
Choose paper source hit <OK>
push <start>Accidents don't just happen. They must be carelessly planned.Comment
poor me, Some of my Canon iR 3200 have problem with cassette, I put the plain paper with letter size in cassette but the printer still says : no paper in that cassette -> I can not select paper source from cassette. I have to used MP cassette only (manual feed cassette).
Tons of troubleshot with iR C3200. Anyway everybody here so kind to help me otherwise i don't know how to do , Thanks a lot.Comment
