Finisher T1,W1 Tray 2 sensor
  • Morales3556
    • Apr 2011
    • 14
    I have a couple of T1,W1 finishers that have the tray 2 sensor broken,is there any way to fix this problem? I have a pictures to show which sensor it is.Any help would be appreciated. IMG_0717.JPG IMG_0718.jpg
  • teckat
    • 16083
    Needs to be replaced/ u can not glue them for repair
    # 4A3-1673-000
    • Morales3556
      • Apr 2011
      • 14
      How do you replace these sensors?
      • teckat
        • 16083
        there is a spring release under both of the trays, see Pic>
        you
        need to push the tray lift motor gear [1] to the front (using a screwdriver or the like) to release the clutch. However, when the clutch is released, the tray [2] drops by its own weight. Be sure to hold the tray with your hand when releasing the clutch.
        u can lift tray A and remove the Upper Face Panel/ to view & replace A Tray Flag
        if B Tray Flag is damaged / u need to remove side panels R/L AND TOP COVER/
        AND remove Tray A + it's stopper on right side> LIFT OFF Tray A/ hang on side/
        see pic > now release B Tray clutch> and slide up a little to view the Lower Face Panel screws/
        REMOVE Panel to view & replace B Tray Flag
        • vigour
          • Aug 2010
          • 1038
          I used to change them till some guy told me he crazy glues them. We use an industrial strength crazy glue.
          • teckat
            • 16083
            makes no sense to waste time & remove covers, especially if B Tray flag is damaged, to play around with Krazy Glue
            • vigour
              • Aug 2010
              • 1038
              I just like to have my fingers stuck together for a few weeks.
              • vigour
                • Aug 2010
                • 1038
                TRy this sometime.
                I used to go the long official route, now i found shortcuts.
                Push both trays down, remove upper face panel
                Push both trays up, remove lower face panel.
                When replacing lower panel, push up on lower tray for a few centimeters more clearance.
                Upper panel takes a little practice and wiggling to get back in.
                Some guy I know does it without removing the upper panel.
                It takes a bit more wiggling to get the lower panel back in.
                It works,real fast.
                • teckat
                  • 16083
                  Thanks, have also have done that procedure when in a hurry
