Canon IR2200
  • jake24482
    • Apr 2011
    • 116
    Canon IR2200
    it lose data from mailbox any body has any idea. please let me know
  • Simons
    • Jun 2008
    • 490
    Go to additional functions/ mailbox settings and change auto erase from 3 days to 0 = OFF
    • kuby
      • Oct 2007
      • 1409
      Ditto....
      • jake24482
        • Apr 2011
        • 116
        it has only three options boxset/store, photo and standard scan settings
        • kuby
          • Oct 2007
          • 1409
          Under boxset/store select Doc. Auto Erase set to 0.
          • jake24482
            • Apr 2011
            • 116
            it is on 0
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              Documents stored within a Mailbox can be set to erase immediately after printing or 1, 2, 3, 6, 12 Hours / 1, 2, 3, 7, 30 Days / OFF. The default setting is 2 hours. When the Mailbox is set to OFF, mailbox documents are not deleted and the imageRUNNER-iR can be used as a filing system.
              Note: To change individual mailbox settings: Select Additional Functions > Mailbox Settings > User Inboxes Settings.
              To change all user inboxes settings: SelectAdditional Functions > System Settings > Settings for All User Inboxes.
              • roho
                • Mar 2009
                • 844
                Are you losing network settings too? I had this, the back up battery was failing.
                • jake24482
                  • Apr 2011
                  • 116
                  thanks all of you guys
