canon ir-105 error E000128-0000
  • tariq65
    • Jun 2010
    • 84
    i gate the problem canon ir-105 error E000218-0000 any body help me.
  • charm5496
    • 2387
    check your scanlamp as it is probably not working.
    Here is further information for you:
    Problem :
    E218 code. The code continues to occur even after the Scanning Lamp has been replaced.
    Solution :
    Try the following:
    • Check J1003 on the Lamp Inverter PCB to determine if the voltage to the lamp is missing.
    • If the voltage at J1003 is missing, then check J1001, pins 1 & 2, for 40 volts and J1002 for the proper signals coming from the Reader Controller. If the measurements are correct at J1001 and J1002, then replace the Lamp Inverter PCB.
    • If 40 volts is missing at J1001 of the Lamp Inverter PCB, it may be necessary to replace the Lamp Inverter Power PCB and / or the Relay PCB.
    • If the signals at J1002 of the Lamp Inverter PCB are incorrect, it may be necessary to replace the Reader Controller.
    • Try reseating the connectors for the PCB's previously mentioned before replacing them.
    • Also, check the wiring visually and with continuity checks between all of the previously mentioned PCB's.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      error E000218-0000 or
      E000128-0000
      • tariq65
        • Jun 2010
        • 84
        thank you sir problem scanner lamp when i start the copy no glow lamp and no move scanner and blank paper come out then give error E000218-0000 .
