Temperature regulation
  • danwatt
    [Electrical] Temperature regulation
    Please can someone advise me on how to increase the life span of my rollers i have canon ir3170 changed the upper roller and in two weeks it's got deformed and start peeling off? Or is there a way to regulate or control the temperature of the heating system?
  • ikon01
    • Apr 2011
    • 53
    whats the life of the fuser assy?we swop ours out complete,they are not worth messing with because of problems such as yours.
      • 16083
      a. Energy Save Mode
      Energy Save Mode is activated/deactivated by a press on the Power Save key. It lowers the fixing temperature and thus reduce the power
      consumption. The rate of saving is selectable in user mode [Common Settings> Energy Save Mode (-10%, -25%, -50% and no return time].
      b. Low Power Mode
      Low Power Mode will shut off only the +24V power supply and will automatically be shifted from standby after the predetermined time has lapsed.
      The period of time until Lower Power Mode starts can be specified in user mode [Timer Settings> Low-power Mode (10 min. to 4 hours)].
      The fixing temperature is controlled at 140 degrees C and a specific period of recovery time will be required.
      c. Sleep Mode
      Sleep Mode will lower the power consumption below the two modes above. It is activated when the control panel power switch is turned OFF or
      after the predetermined time has lapsed. The period of time until Sleep Mode starts can be specified in user mode [Timer Settings> Auto Sleep Time (10 min. to 4 hours)]. The fuser is turned OFF and a specific period of recovery time will be required. This mode can be turned OFF in service mode [COPIER> Option> USER> SLEEP> 0 (1: ON by default)].
      Note:
      Since Low Power Mode cannot be turned OFF in accordance with Energy Start Program although Sleep Mode can be, the host machine will shift from standby to Low Power Mode after 4 hours at the longest. If Sleep Mode is activated and the period of time until Low Power Mode starts is shorter than that of Sleep Mode, the host machine will shift from standby to Low Power Mode and then to Sleep Mode. However, in the contrary case, the host machine will shift to Sleep Mode without shifting to Low Power Mode.
        • 16083
        Prevention of Partial Deformation of the Roller (otherwise caused by no use over time)
        The fixing roller can start to suffer deformation if left alone for a long time under temperature control (because of its nip). To prevent deformation, the machine rotates the fixing roller at 68.5 mm/sec (half speed) for a period of 0.5 sec every 30 min (during standby).
        When the machine starts sleep mode, the machine turns off the power to the fixing motor (M11) to prevent the fixing motor from rotating; however, since the machine does not perform temperature control for fixing in sleep mode, the roller will not suffer deformation even when it remains stationary.
        The machine performs temperature control for fixing while it is in power save mode (-50%) or in low-power mode, and turns off the power to the fixing motor (M11), thus preventing the fixing roller from rotating. If such a condition lasts for 4 hr or more, the roller can start to suffer deformation; the machine, however, is designed to shift to sleep mode before the passage of 4 hr so that the roller cannot start to suffer deformation.
        • danwatt
          Ans
          It is about a year
          • WOETC
            Originally posted by danwatt
            Ans
            It is about a year
            That's how long before you throw the whole copier in the trash.
            In the 6800 series there is a setting in service mode to shorten the time between rotations of the fuser when it's idling. I can't remember it offhand, but it helps on that machine. It also helps to reduce the nip pressure.
              • 16083
              adjusting fixing temperature in service mode [COPIER> Option> BODY> TEMP-TBL> set to "1" or "2"].
              Use it to adjust the fixing assembly control temperature.
              0: OFF
              1: +5 deg C
              2: -5 deg C
              The new settings become valid only when the main power switch has been turned
              off and then on. [at time of shipment/after RAM initialization: 0]
              • ciaran
                • Mar 2011
                • 45
                this canon bulletin should fix your problem
                ir3100c-028 fuser.PDF
