Canon IR C5870U
  • Jaws
    • Oct 2007
    • 236
    Canon IR C5870U
    I am getting the error message E0061-003. Been on Canon's forum and found a few possibilities but no solution.
    This code means the potential sensor has reached a higher than required voltage.
    1. I change the potential pcb assembly, sensor and wires.
    2. I check the drum for rotation as they say a screw can break on the drive gear in the back.
    3. I made sure I had a good ground contact in the back on the HV1
    One person mentioned that they turned of the v-con which stops the potential sensor from taking a reading.
    I would like to try this but can't figure out how to turn it off.
    Anybody have any ideas on this subject?
  • Canuck
    Tech Specialist
    • 1713
    are drum voltages ok? Vl,Vd?Check for slippage of the drum drives at the rear..had one where allen screw was loose and too short on drum drive shaft
