IRC2880i - color problem...
  • msmy
    • May 2010
    • 123
    Hai guys,
    I have a problem with IRC2880i, which is the output colour is differ then original. Please see attachment. Any ideas how to solve this prob? Thank you.
    the color should be green, however its look like rainbow color...
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Usually is drum issue.Print PG-10 in service mode test post a pic and we will see whats wrong.
    • Van Steal
      • 177
      Make sure your laser mirrors are clean. There should be a blue tool on the inside of the front door and instructions on how to use it.
      • ciaran
        • Mar 2011
        • 45
        looks like a yellow drum issue, but as zoraldinho says print pg -10 in service mode and it will give you a definite answer
        • Canuck
          Tech Specialist
          • 1713
          Just go into service mode,hit COPIER, then misc and read the drum life. If the drums are ok do Pascal(auto gradations).As stated the test print will help
          • msmy
            • May 2010
            • 123
            tq guys. I'll do it as suggested today.
            • msmy
              • May 2010
              • 123
              Dear All,
              Attached is a PG-10. Please advise. tq.
              • zoraldinho
                • Mar 2008
                • 5015
                If you clean laser mirrors,check yellow drum life.(replace yellow drum)
                • mezerwi
                  • Aug 2010
                  • 58
                  Hi msmy, betul dah tu drum kuning ade prob.
                  • Irish
                    • 110
                    Change yellow drum
                    • ciaran
                      • Mar 2011
                      • 45
                      check the yellow dev clutch, these can seize or the bushing that holds them in can crack and fall out
                      • ciaran
                        • Mar 2011
                        • 45
                        heres the part numbers for clutch and bushing
                        • msmy
                          • May 2010
                          • 123
                          Thank you to you guys. I just order new drum today, hopefully I can get it by this week. I'll check the bushing as suggested by Ciaran.
                          cheers...
                          • zoraldinho
                            • Mar 2008
                            • 5015
                            [ATTACH=CONFIG]10000[/ATTACH]
                            Good point dude.
                            We still need to know drum life counter!
                            • msmy
                              • May 2010
                              • 123
                              drum life for Y is 28
