Canon ir5000 ripping legal and jamming at turnaround
  • mrfixit
    Senior Technician
    • Sep 2007
    • 83
    I have a canon ir5000 that is ripping legal paper on the turnaround guide when it flipps over for face down output, swapped the duplex and cleaned the one ways and scuffed the shafts, going back in the morning with exit roller and oneway gear. Does anyone have any other suggestions, it works fine on letter paper, never bothered checking letter R. Any help would be greatly appreciated.
    Ray
  • kuby
    • Oct 2007
    • 1408
    Also check the flapper arm (FB5-3394-000), it controls the flapper guide in the upper delivery assembly. It could be cracked. It about drove me crazy till I found it.
    • mrfixit
      Senior Technician
      • Sep 2007
      • 83
      Oh yes I know that flapper, usaully the paper won't even go into the duplex when that goes but I'll be sure to check it.
      • jake24482
        • Apr 2011
        • 116
        i had that problem three time .i had to remove the gray guide next to reversal paper guide and it work fine .it had only one screw toward front .just take it out it will be fine
        • jake24482
          • Apr 2011
          • 116
          sorry it has screw in back .part #fb5-3307
          • Canuck
            Tech Specialist
            • 1713
            Common on 5000 around a million. Replace internal and external delivery rolls and bearings along with one way gear on internal delivery roller assembly. There is an old bulletin about this issue. Only occurs on legal and 17 inch
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Canuck is dead on with the answer, my small contribution is this:
              These parts are needed to rebuild the fuser exit/inversion area to get rid of ripped legal length copies from slowing up in the inversion process.
              FB6-5892-000 Roller
              FB6-5895-000 Roller
              FB6-5896-000 Roller
              FS7-0660-020 1-way Gear
              FS7-0664-020 1-way Gear
              • Simons
                • Jun 2008
                • 490
                if its got 500000 plus check check the flapper for nicks and i would replace the duplex paper sensors. If you take them out you can find them very worn down and often cut. Especially if you work with the likes I used to.
