send function in IR1022if
+ More Options
Posts
  • Mina Banoub
    • May 2011
    • 50
    [CQ] send function in IR1022if
    Hi,
    I connected an IR1022if to my pc throught a usb cable and also with a crossover cable . I can print through the two connections and i can scan documents( pull scanning ) . the thing i cannot do is i cannot send a file to a shred folder on my pc (i registered all the data needed in the registration process in the addressbook setting "additional function mode") but i am getting a faild report each time. P.S. I can send a file to a shared folder on the same pc using an ir5055n "windows smb"
  • Gbr
    • Nov 2011
    • 50
    Re: send function in IR1022if
    have the same problem.on the report which error number is print out?
    somebody said that machine needs to be re-booted,and if everything is correctly put in,should work.
    if you manage to make it happen without re-booting please send me the settings(network,adress) report.or if anybody have documentation
    describing how to configure it step by step as well.
    tim.gabr@gmail.com
    ps. are you using remote UI?
    thanks!
    Gbr
