Error code 732
  • BIMAN CHANDRA NATH
    • Apr 2011
    • 42
    [Error Code] Error code 732
    I am working with iR 3225 machine,the problem is that after replacing the reader controller pcb the error code E732 is displaying.If I off the reader unit from service mode the machine is working perfectly ok as a printer. Please suggest what to do now.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    What was the purpose of replacing the reader controller board in the first place?
    • Canuck
      Tech Specialist
      • 1713
      Start with a RAM clear on RCon and update firmware. RCon firmware might be outdated or corrupt
        • Apr 2011
        • 42
        Reader controller was burnt out,so we have to change the pcb.After changing the pcb we update the firmware but the problem was the same.After that we change the relay pcb and over the problem.
