Colorpass Z400e power problem
  • gmamadog
    • Jan 2011
    • 7
    [Misc] Colorpass Z400e power problem
    i have a canon clc 1140 with a colorpass z400e attached. this setup has worked well for me for many years but recently the power on the colorpass has been sketchy - sometimes powering up and sometimes not. a week ago i tried powering up the colorpass and noticed that the power came on for a second - long enough for the fans to turn a revolution - and then shut down. trying to repower up the unit does nothing at all - no fans, lights, or anything. if i let the unit sit unplugged for a period of time the colorpass will give the original symptom - fans, lights, for a second and then no power. has anyone run into this and found a solution?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Just as with any other PC (which this is, actually), it sounds like the power supply or motherboard has decided to call it quits.
    Unless you can get the parts really cheap, like by someone here at Copytechnet or on eBay, it's probably not worth messing with. You can very likely get the entire RIP (or a different model that would work) for a very decent price.
    • gmamadog
      • Jan 2011
      • 7
      thanks ken. i was thinking power supply but i don't have a manual. i'll let you know what it winds up being.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        The Canon part number for the power supply is: FE1-5267-000.
        • alexctx
          • Dec 2010
          • 157
          the source is wrong.
          change it and it is.
          also you can adactar a source of pc come with inteructor.
          only together on automatic (green) with Earth (black).
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            and looks good[ATTACH=CONFIG]10030[/ATTACH]
            Huh???
            • alexctx
              • Dec 2010
              • 157
              here to do that because it does not sell the power of origuinal and works very well.
              the bridge do the cables before before arriving to the connector.
              • teckat
                • 16083
                Funny thing about this Z400e is that if you plug in both the ColorPass and printer in same outlet,and there is something else sharing this outlet without your knowledge-
                u will have a voltage drop over 10/15% - this would drive me crazy at some accounts-
                discovered some accounts had microwaves/toasters/refrigerators/other printers plugged on same line in other rooms on the floor
                FE1-5267-000/ 199.00 US
                POWER SUPPLY UNIT
                • Van Steal
                  • 177
                  as KENB said
                  Huh?
                  • teckat
                    • 16083
                    Originally posted by Van Steal
                    as KENB said
                    Huh?
                    Puente=Bridge=
                    Bypass the signal / short green to black
                    • Van Steal
                      • 177
                      Originally posted by teckat
                      Puente=Bridge=
                      Is that safe?
                      • teckat
                        • 16083
                        Is that safe?
                        depends on what that signal controls/
                        I short pin out the cleaning brush motor on the CLC 1100 / to prevent lock up on Trans Drum
