Canon IR6000 problem
  • ZoLion
    • Dec 2007
    • 10
    HI!
    I can't change the fixing temperature on one of our IR6000. The temperature is 203 C
    Every morning, the copier indicate E001 error, but the temperature under 230 C, always stop 203 C
    Can you help me?
    Thanks.
    • 23009
    Are the thermistors clean, in good condition, new, and contacting the roller evenly-flatly? Is it the correct part # upper & lower fuser rollers? That's where I would start.
    Adjusting fuser temperature typically is just masking some other problem, even if it helps (which it usually doesn't).
    • lkrsardis
      • Dec 2007
      • 316
      e-001
      replace th2# fg5-8812-040.
      these have been known to cause this problem.
      good luck.
      Like the United States Postal Service It's a miracle it works!
      • vandezo
        I don't know
        • 161
        clear error
        blackcat is right, check the part...
        i had the same problem, then i change the upper roller
        e-0001 is dissapear ..
        • kwazimoto
          • Jan 2007
          • 199
          Also check the connector board under the lower fuser roller it can cause fuser errors also.. spray out all connector and check for paper in the fuser connector the one on the back frame also make sure there is good connection between both halfs of the connectors
          • OtherTech
            • Aug 2007
            • 94
            I always start by replacing th1, always worked so far.
            • irwan zamroni
              • Dec 2007
              • 12
              i have servis manual 6650,but..........
              assalamu'alaikum. I have servis manual 6650,but i need servis manual Ir6000,any body can barter with me.u can e-mail me irwan_zamroni@yahoo.com
              • irwan zamroni
                • Dec 2007
                • 12
                try to refixing the thermistor possition.i guess it position to near from UFR
                • ZoLion
                  • Dec 2007
                  • 10
                  Thanks for everybody! I cleared the thermistors, and everything is ok!
                  Thanks.
