E 315 advance 6055
  • vigour
    • Aug 2010
    • 1038
    [Electrical] E 315 advance 6055
    Had a 45 minute look at an advance 6055 with E315 -0540 this evening.
    Reseated memory
    Updated system to v31.
    Copier has Uniflow running
    Each time it restarts, it tries to complete sending a scan job, then dies, whether the door is open or the fuser is disconnected.
    Any ideas????
  • teckat
    • 16083
    Reseated memory
    Any ideas????
    Perform the following
    All Data Initialization:
    Settings and Registration > Log In > Management Settings > Data Management > Initialize All Data/Settings
    this will take about 20 minutes to complete.
    • vigour
      • Aug 2010
      • 1038
      Thanks pal.
      I Will try that in the morning
      • vigour
        • Aug 2010
        • 1038
        Thanks Teckat
        Tech support told me to do the initialization, but I needed a second opinion.
        Any way I was able to find an alternate method, because the IT guy was not there early, and I could not get to the additonal functions screen, because I had no acess to Uniflow.
        So I tried methodically HD CLEAR 0,1 and 2 , The machine crapped out after each.
        I got tired of turning it on and off to clear error, so I did Clear 3-8 all in a row. The send job disappeared and the code stopped appearing.
        I found Clear 4 and 6 said NG , but it was not significant,
        I checked Clear 4 and 6 on anothe working machine and it said NG also.
        I was told that doing INITIALIZATION would require a reload of UNIFLOW.
        So basically I stumbled upon a shortcut
        • teckat
          • 16083
          u should try and re-load iRAD 6055 first-
          found out this is a Canon known issue error code when scanning
          U Can not clear chk-type 4
          service mode
          • vigour
            • Aug 2010
            • 1038
            Good to know
            • vigour
              • Aug 2010
              • 1038
              I had another E315-0540 today.
              After disconnecting the network cable doing HD CLEAR type 5, a bunch of NG email reports printed out , then everything started working correctly.
              • teckat
                • 16083
                Wanted:
                Canon Engineer who knows it all, and then some !!!!!
                Experience:
                1. Know right from left
                2. Know left from right
                • gunny
                  Re: E 315 advance 6055
                  Reseated memory
                  Any ideas????
                  I updated firmware and went to, settings and registration>send settings>email and fax settings and maxed out the size to 99mb and it worked, two of my machine have been working for over a month now
                  • charm5496
                    • 2387
                    If you set it to a '0' there is no limit placed on the file at the machine level.
                    • vigour
                      • Aug 2010
                      • 1038
                      ​nice feedback guys
