IR105 start up hang.
  • addoncopier
    • Feb 2010
    • 114
    Another IR105 i got a problem which is after paper jam at 0211, 0218 machine hang can not reset. Need to on off. Sometime, on off also can not, during start up, machine do warming up, but screen shown Wait.... After that Code appear E000732-0001
    What should i do?
  • V-P
    • Apr 2011
    • 679
    Disconnect and connect the connectors of the read communication cable.
    Check the power supply of the reader unit (to see if initialization occurs at power-on).
    • addoncopier
      • Feb 2010
      • 114
      i reconnect the connectors of the read communicaiton cable. it works. but later on it come again for E000733-001
      • V-P
        • Apr 2011
        • 679
        It means : An attempt to communicate with the DC controller fails.
        Disconnect and then connect the connector.
        Check the power supply of the DC controller (to see if initialization occurs at time of start-up).
        Twisted cables you have there huh ....
        If I were you I would give a good clean to the machine and re seat most of the cables.
        • addoncopier
          • Feb 2010
          • 114
          V-P now machine start running, when paper jam no hang. but i found that the speed of the machine not constant always delay. Sometimes paper jam. I touch the break cluth FH6-5014 before transfer charges, i got electrical shock. What's going on actually for all these.
          • V-P
            • Apr 2011
            • 679
            I am sorry my friend but your English and my English differ by some zip codes.
            But from what I can understand your machine has been "beaten up" and needs a lot of replacing and a good grounding.
            • addoncopier
              • Feb 2010
              • 114
              Ya, my english very poor. Nevermind. Ok Now let's solve it by code. 0110,0101,0211,0218 what should i change?
              • V-P
                • Apr 2011
                • 679
                I don't like your attitude man !
                It shouldn't be : What can I change !
                It should be : I should have cleaned the copier first and than ask for help !!!!
                So - to give you some idea:
                01xx delay jam
                02xx stationary jam
                xx01 right deck pickup sensor (PS20)
                xx10 duplexing outlet sensor (PS61)
                xx11 pre-confluence sensor (PS14)
                xx18 Image write start sensor (PS60)
                It is useless to copy/paste the jam codes of your machine if you don't clean the sensors.
                Might I suggest getting a Service Manual ????
                • addoncopier
                  • Feb 2010
                  • 114
                  For the 0211, i already solve.If you have service manual, please send it to me. Thank you.
                  • V-P
                    • Apr 2011
                    • 679
                    All I have is passion for this job.
                    For service manuals I am afraid you must ask other users
                    • V-P
                      • Apr 2011
                      • 679
                      However, here is the needed section from that manual
                      Pages from ir8500-sm.pdf
                      Cheers
                      • addoncopier
                        • Feb 2010
                        • 114
                        V-P, I already solve the problem of my machine. Thx for you info. Right now, This machine got another problem. E583-001, always happen. I check the sensor from the tray no problem. I do try to set the setting that only tray A is using. But still i have E583-001 problem. What's wrong actually?
                        • V-P
                          • Apr 2011
                          • 679
                          this is a finisher error.
                          E583 (tray auxiliary plate motor M6) - Tray auxiliary plate home position sensor (PI10)
                          The tray auxiliary plate housing sensor does not go ON within 2 sec after
                          the motor is started when the tray auxiliary plate is retracted.
                          Like I said before : Your machine needs cleaning
                          • addoncopier
                            • Feb 2010
                            • 114
                            This finisher i clean 3 times already. No dust. Still E583-001 is coming. Weird. Maybe the finisher PCB need to replace?
                              • 16083
                              Product : imageRunner 7200 / 8500 / 105
                              Finisher K1 / K2 / K3 E583 Error Code
                              E583 Error Code
                              Try lubricating the Shaft (Figure Q23) for the Pulley's and replacing the both Pulleys, item number 5 ( FS5-3747-000) and item number 4 (FS5-3746-000) repaired the E583.
