IR 3235 Touch screen completely dark
  • amizzz
    • Aug 2025
    [Misc] IR 3235 Touch screen completely dark
    The IR 3235 does nt display nothing i tried to adjust the contrast but negative result however copies are coming out as well but no acces to the settings panel . what may be the problem?
  • jake24482
    • Apr 2011
    • 116
    see if hear beep when you push any key . if you do its possibility the back light went out
    • teckat
      • 16083
      imageRUNNER 3225 / 3230 / 3235 / 3245 Blank LCD Display or No Power to the Main Unit
      When the Main Unit is turned on, either a blank LCD display occurs or no power occurs. In some cases, the control panel buttons work, but the display is blank.
      If the Main Controller "registered value" ID does not match the REAL TIME CLOCK (RTC) ID, the Main Controller Malfunctions; preventing the LCD display from powering up or no power to unit. By shorting JP1 on the Main Controller it will clear the RTC "registered value", to correct the ID between the Main Controller and RTC Circuit.
      Procedure:
      1.
      Turn OFF the Main Unit.
      2. Either unplug the power cord from the wall.
      3. Remove the rear cover of the Main Unit.
      4. Below the left leg of the Battery, jump JP1 for 3-5 seconds.
      5. Plug in the power cord and turn on the Main Unit.
      6. Verify that the Main Unit powers ON and that the LCD display works.
      7. Re-install the rear cover.
      • godyng
        • Dec 2008
        • 40
        this must be the inverter defect !!
        • Monsoon
          • Nov 2009
          • 16
          Is the green light showing on the LCD panel?
          Also, Teckat, how do you short this pin? I am not familiar with this method. I usually just replace the LCD screen.
          Thanks,
          • teckat
            • 16083
            Thanks,
            with a Paper Clip - bend in U SHAPE / FOLLOW INSTRUCTIONS ABOVE/
            TOUCH ACROSS THE TWO BUMPS OF J1
            • Monsoon
              • Nov 2009
              • 16
              That Is exactly what I'm looking for teckat, thank you. Is this the same for all models? Only I have had this screen fault oh iRC2380i. Is the RTC ID kept on pin JP1 on all machines?
              Thanks in advance
              • teckat
                • 16083
                have only seen it on this series
                • stupidlarlar
                  Re: IR 3235 Touch screen completely dark
                  [ATTACH=CONFIG]10155[/ATTACH]
                  I jump the jp 1, but the screen still remain dark, anymore solution?
                  • teckat
                    • 16083
                    LCD Display is completely Blank
                    LCD Inverter PCB
                    new style LCD Inverter PCB (Part Number FM4-6690-010) now has a jumper, JP4, on it. Also, there may be one of two different style LCD's in the machine, each with a different style connector to the Inverter PCB. There are two positions for jumper JP4 depending on which LCD you have.
                    If the LCD Display's connector plugs into J2 on the LCD Inverter PCB, the jumper for JP4 should be positioned all the way to the left for the LCD Display to work properly. Please refer to the picture below:
                    If the LCD Display's connector plugs into J3 on the LCD Inverter PCB, the jumper for JP4 should be positioned all the way to the right for the LCD Display to work properly. Please refer to the picture below.
                    • jacky_kuo
                      • Aug 2011
                      • 54
                      May fuse broken ,
                      my experience !!
                      • willhus
                        I am having the same problem and will try the jumper trick
                        • Canuck
                          Tech Specialist
                          • 1713
                          Install the new style inverter pcb...i've changed about 20 of them for this problem
