adding IP-C1 to c3200
  • ReproKev
    • 273
    Cust wants to add a C1 to their c3200 that has normal ps/pcl printing now. I haven't done that before. If I swap out the boot Rom (C for N), remove the surf pcb and replace with open interface pcb. Then change IMG-Cont from 0 to 3 in service mode. Is there anything else that needs to be done?
  • teckat
    • 16083
    The imagePass C1 requires the C Boot Room/this C boot rom came with printer
    The N Boot Rom is form the Multi-Pdl Kit u now have in Printer
    see C1 install pdf>>>imagePass C1 v2 Install.pdf
    • ReproKev
      • 273
      Thanks for the info.
