Canon IR 3100C error code E000020-0081 Help pls!!!
  • chandra_mithra
    • Jun 2011
    • 16
    [Misc] Canon IR 3100C error code E000020-0081 Help pls!!!
    Hi, am trying to troubleshoot the error code E000020-0081 in Canon IR3100C copier machine. I have already refilled the cartridges with toner. However, it is still displaying the same error code and unable to repair it. Can anyone guide me with the steps to resolve the issue? Video guidance if available will be much appreciated. Thanks in advance.
    Keshava
  • chandra_mithra
    • Jun 2011
    • 16
    I was able to resolve the issue. I removed the drum unit and then cleaned the censor above the drum unit. that resolved my issue.
    • teckat
      • 16083
      • Mrigen
        • Oct 2011
        • 19
        Re: Canon IR 3100C error code E000020-0081 Help pls!!!
        P-SENS-P is less than 255 when a base
        (drum face) of patch detection is read
        out.
        Go 2 COPIER>DISPLAY>DENS>P-SENS-P and check d value if it is less then 255 Clean the patch image reading sensor
        • teckat
          • 16083
          out.
          poster fixed issue back in June 10,2011
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            06-10-2011
            • vallvejo
              • Aug 2011
              • 10
              Imprime primero un p-print con todos los datos de servicio y luego hazle un clear DC-CON y solucionado.
              • teckat
                • 16083
                Try printing one p-print with all service data and then try a DC-CON clear and fixed.
                POSTER SOLVED THE ISSUE ON June 10,2011
                just a note>
                u can't PRINT A P-PRINT IF THE PRINTER IS IN AN ERROR CODE ~~~~~~~~~~~~~~~~
