Canon IRC3380i problem
  • msmy
    • May 2010
    • 123
    [Error Code] Canon IRC3380i problem
    Dear All,
    I have a problem with canon IRC3380i which is when I on the copier, error code E000990-000 appeared. Then I check drum (look ok) and waste toner (look fine). Anyone please help me how to deal with this machine...
    msmy
  • teckat
    • 16083
    imageRUNNER C2550 / C2880 / C2880i / C3380 / C3380i / C3480
    E990 0000 When the locking Handle for the Process Assembly is turned to the locked position it re-positions a rack that opens the Waste Toner Shutters. When the rack is in the correct position there is a cutout in the rack that unblocks PS12, if the sensor remains blocked an E990 0000 will be generated.
    Remove the Hopper Drive Assembly and the Hopper Assembly .
    With those items removed you will see a white nylon gear plate with 2 locking screws. Loosen the locking screws and position the gear plate so that when the handle is in the locked position, the cutout in the rack unblocks PS 12. (See photo below)
    Canon USA, Inc. Systems & Technical Support Division
    • teckat
      • 16083
      imageRUNNER C3380 / C3380i / C2880 / C2880i Error E990
      When the process unit black locking lever is locked or released, it in turn opens/closes a waste toner shutter mechanism, if this does not occur properly an E990 error code may occur.
      Solution :
      Check the Cam Lead mechanism (on inside process frame) for any broken gears or a broken cam lead itself, item #24 FC6-9403-000. (See attached image for parts location).
        Following on from Teckats advice
        E990 0000 .pdf
        • CanonSco
          Man About Town
          • Jul 2010
          • 368
          Solution :
          Had that twice. Worth checking as the man said.
          Yes, I am a nerd.
          Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
          • msmy
            • May 2010
            • 123
            Thank guys. I'll check it today.
            • msmy
              • May 2010
              • 123
              Yeah. Finally I solved this problem. Thank you guys...
              • CanonSco
                Man About Town
                • Jul 2010
                • 368
                And, what was it in the end?
                Yes, I am a nerd.
                • teckat
                  • 16083
                  the solution was ____________ !!!
                  • mark121381
                    • Jul 2011
                    • 85
                    Re: Canon IRC3380i problem
                    [ATTACH=CONFIG]10277[/ATTACH]
                    Sir Teckat ,
                    Thank you for this info, it really help me a lot... Now the machine is working properly... More power...
                    Hope you can post more info. tnx
                    • teckat
                      • 16083
                      ELVIS.jpgthanks,good luck
                      • Zetterber
                        • May 2014
                        • 8
                        Hi, I know I am replying to an old thread however I have this exact problem, E000990-0000 however when I try to open the links in previous posts none of them work, does anyone have a working PDF of where the parts are located?
                        I have attached a photo of a broken gear that fell out of the machine but I have no idea where it came from. Anything anyone can help with would be great.
                        Thank You
                        • teckat
                          • 16083
                          [ATTACH=CONFIG]25194[/ATTACH][ATTACH=CONFIG]25195[/ATTACH]
                          Thank You
                          Check the Cam Lead mechanism (on inside process frame) for any broken gears or a broken cam lead itself, item #24= FC6-9403-000. (See attached image for parts location).
                          also
                          E990 0000 = Shown on the Display
                          When the locking Handle for the Process Assembly is turned to the locked position it re-positions a rack that opens the Waste Toner Shutters. When the rack is in the correct position there is a cutout in the rack that unblocks PS12 (WG8-5772-000), if the sensor remains blocked an E990 0000 will be generated.
                          Remove the Hopper Drive Assembly (p10-23 to p10-25 in the Rev.0 Service Manual; p10-21 to p10-23 in the Rev.1 Service Manual) and the Hopper Assembly ( 7-66 in the Rev.0 Service Manual; p7-48 in the Rev.1 Service Manual). With those items removed you will see a white nylon gear plate with 2 locking screws. Loosen the locking screws and position the gear plate so that when the handle is in the locked position, the cutout in the rack unblocks PS 12 (WG8-5772-000). (See photo below)
                          • teckat
                            • 16083
                            Thank You
                            That 16T GEAR looks like FU3-0293-000/
                            Location inside Middle or Large Cassette / used for size side plate paper adjustments / Known issue of breakage
                            • Zetterber
                              • May 2014
                              • 8
                              [ATTACH=CONFIG]25196[/ATTACH]
                              [ATTACH=CONFIG]25197[/ATTACH]
                              Thanks so much for this information, glad to know that the gear is not particularly important for the functionality of the machine. The gear has actually broken off form whatever it was connected to. Is there a part number that you may know to actually replace this part with. I will try to get the real problem solved later today I did take a brief look but its not so easy to get all those wires out of the way and disconnected, is there an "easier" way then actually removing all those purple wires running below the toner cartridges.
                              Thanks Again!
