IR6000 WasteToner
  • ar6565
    • 94
    IR6000 WasteToner
    The IR6000 has waste toner on T/S Corona rear base?
    I cleaned the pre-sepration Corona I Dev is Ok. But it still has WasteToner on the T/S corona.
  • CT Copier Repair
    • Mar 2010
    • 304
    Did you empty the waste toner container
    check the cleaning blade cleaning unit seals
    drum seals etc
    sounds like its dropping or backing up
    You have to clean to make it stop
    • kuby
      • Oct 2007
      • 1408
      Check and make sure that the auger is turning. Had them freeze up and break the gears on the front of the cleaning unit.
      • mr.daus
        • Apr 2011
        • 98
        be sure to chek drum unit clleaner asembly,,,
        chek gear cleaning
        firdaus +(62)8195002007 firdaustrish@ymail.com
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          As people have already mentioned, your auger has seized in the clean station, bring your vacuum and putty knife to get the auger moving again. More than likely you will find these two gears stripped or broken in the front drive cluster...
          FS6-0862-000
          FS6-0124-000
