Poor copy in Canon IR3100
  • chandra_mithra
    • Jun 2011
    • 16
    [Misc] Poor copy in Canon IR3100
    I have got a problem with my Canon IR3100. The copies turnout blurr. And then I clean the Cleaning blade (polyurethane rubber) near the drum unit with a piece of cotton. Once it is cleaned the next 10 - 12 copies come out good. The next copies will be blurr again. I have to repeat the cleaning work after every 10-12 copies. I am fedup. Is there anything else I can perform apart from manually removing the drum unit everytime and cleaning the cleaning blade after every 10-12 copies? pls give me suggestions.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5002
    Check drum and cleaning ITB blade life.Post a pic with PG 10 test.
    • chandra_mithra
      • Jun 2011
      • 16
      K. thanks. that makes it fine now.. big thanks to copytechnet.com and all the service engineers. u ve been very helpful
      • chandra_mithra
        • Jun 2011
        • 16
        I have replaced the ITB cleaning assy. Now the copies are coming out good. thanks a lot sir.
