Blurred Horizontal white lines in heavy paper- Canon IRC5180
  • digitalbrain
    • May 2010
    • 29
    I am getting horizontal blurred white lines constantly at the same place (app 327mm)from the leading edge when printing on 12*18 256gsm card selecting Heavy2. When I select the "plain paper" instead of heavy2 to print, this problem is not there.
    Any ideas ?? Thanks in advance
    DB
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    I bet on the fixing assy.Problem is a fixing speed.
    • digitalbrain
      • May 2010
      • 29
      It shows in all colors..
      • charm5496
        • 2387
        fuser belt has wrinkles on it probably. The heavier the stock and the more toner coverage you have the more you will see those lines.
        • alexctx
          • Dec 2010
          • 157
          where you are.
          this defect have all the irc 5180.5185
          • alexctx
            • Dec 2010
            • 157
            your done
            . A3, 11x17, 12x18.
            you get some testing in heavy 2.
            or printed on heavy 2.
            fuser is not, ITB, drums, etc..
            always get the end of the inaccuracies.
            • teckat
              • 16083
              Color imageRUNNERs - Recommended Simplex mode for best results on specialty stock media
              Recommended single sheet feed for conditions greater than 70% r.h
              try this>>>
              Increase the fixing speed for heavy media with service mode level 2 COPIER>OPTION>BODY>FX-SPEED2 (the larger the value the faster the fixing speed).
              when u switch from plain to heavy and have missing areas in MAIN SCAN (CROSS-FEED)
              most likely your Drum Drive Assembly is getting ready to crap out
              / the clock pulse motor goes bad
              run some PG 10 Prints on heavy stock and post them-
