preventing a fault in cleaning and warping of the blade IRA 7000/9000
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    irac9000-013.pdf
  • teckat
    • 16083
    Originally posted by zoraldinho
    [ATTACH]10404[/ATTACH]
    • vigour
      • Aug 2010
      • 1038
      page 3 has a contradiction
      see below:
      2. Turn the ITB Drive Motor clockwise manually to turn the ITB until lubricant applied on the ITB is covered
      by the ITB Cleaning Unit Scoop-up Sheet[2]. (The applied lubricant passes through the ITB Cleaning Unit
      Scoop-up Sheet[2].)
      *Be sure to turn the ITB Drive Motor counterclockwise only and be careful not to turn it clockwise.
      3 .Points to Note when Applying Tospearl 240 lube(FY9-6007-000)[1]
      CLOCKWISE is the correct direction
      • vigour
        • Aug 2010
        • 1038
        additional related info
        blade plate.pdf
        This was released in 2010 , now re-released for some V2 machines
