Need cassette tray for iR3045
  • jsw2k
    • 95
    The little plastic post molded into the tray is broken and, as a result, the side-to-side paper guides drift.
    But I can't find a part number in the manual. Does anyone have that part number?
    Or, better yet, is there another fix than replacing the whole tray?
    Thanks!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Post a pic for little plastic.
      • 16083
      Cassette Body Gear Post Breaking
      The following procedure is an alternative fix for the paper width guide gear posts breaking.If you should have this issue, follow the procedure below.
      Please Note:
      This procedure is not officially supported by Canon U.S.A., Inc. This suggestion is a field Remedy that has been brought to our attention and is being shared for your benefit.
      PROCEDURE:
      You must remove the following (4) screws from the cassette body. The 4th screw is in the upper left of the picture (not shown) and will need to be removed when you slide the side guides all the way into the center.
      Remove the right side silver metal guide
      Remove the plastic lift tray so you can get to the gears
      Lift up the silver lift plate
      There are two gears that help with the side guide movement, but with this fix you will only need to use the one that is underneath the silver lift plate. Next find the “center point” of where the gear under the lift plate sits and drill 3/16” (approximate size) hole using a drill or small round file.
      This is a view of what the hole should look like in order to insert the new gear post.
      Note:
      Before inserting the post make sure to clean up the area around the hole otherwise the gear may not sit flush.
      This is an Aluminum Binding Post (3/16 x 1/4) and the nut Side that is circled should slide in from the bottom of the cassette.
      Before inserting the rear on the new post, make sure that the arrows on both the Front and Rear Rack are properly aligned (the following pictures shows the proper alignment before sliding the gear on) once the gear is on you can then insert the Screw Side of the post.
      Website to Purchase the Binding Posts Screws: Amazon.com: Charles Leonard Inc. Aluminum Screw Posts, 0.25 Inch Post Length, Silver, 100 per Box (3701L): Office Products
      When installing the gear, make sure the 2 dots on the gear align with the arrows on the guides.
      Adjust Rear Side Guide before tightening the screws. Insert the Rear Side Guide and re-attach the four screws fully to the rear side guide, but do not tighten them. Set the Front Side Guide in the LTR position. Insert about 10 sheets of LTR paper in the tray and move the Rear Side Guide firmly against the paper and tighten screws. Carefully remove the stack of paper and tighten the 4 screws.
      • jsw2k
        • 95
        Thanks...pics not posted?
          • 16083
          Note:Before inserting the post make sure to clean up the area around the hole otherwise the gear may not sit flush.
            • 16083
            Final Check of tray/
            I have tried this/ time to do this is a waste/ no part # for post/
            Canon did re-enforce in updated trays/ they still break/
            this is a Customer issue cause - by not adjusting trays before placing down paper/ and forcing over slide when paper is already in tray/
            we bill Customer for this damage
            • jsw2k
              • 95
              I'm gonna bill the client, also, it's clearly their faulty, or I'd have had a lot more of them.
              But I can't find the part number for the tray. It's on an IR-3045.
              • mrfixit51
                Lead Service Technician
                • 1975
                I used to mark the proper spot where the rear guide was supposed to be, then drill down from the top just the right distance for the screw threads to bang into the rear guide. Then insert one of the self tapping screws that Canon uses in there plastic parts up thru the bottom of the tray and it is permanently repaired.
                If the tray is running Letter orientation, there is a small plastic pad that has sticky tape on it, and you wedge it behind the rear guide of the cassette. It holds it in the perfect spot for letter paper. Just remove the broken gear, stick the wedge in place, push the guide back into position, load the paper and you are good to go...
                FC8-8828-000 you need 2 per repair.
                Upper Cassette FM2-0141-020 1
                Large Cassette FM2-0142-010 2-3-4
                • jsw2k
                  • 95
                  Thank you...everyone. I'll try the fix, then the cassette.
                  • charm5496
                    • 2387
                    We are using these kits to repair our broken cassettes, they last a lot longer than the screw post fix.
