CCD issue
  • adhy
    • Feb 2011
    • 109
    [Electrical] CCD issue
    hi what the solution for the copies problem the left side A3 paper size of direction copy was solid black about 10 cm.
    i had clean the mirror, primary charge, transfer,laser unit and at last i swap the CCD unit
    the machine IR 6020 copieng normally. this problem occurs for LGL and A3 paper zise.
    my question, is there a trick to repair or setting The CCD to solved this issue?
  • adhy
    • Feb 2011
    • 109
    CCD issue
    hi CanonTech i hope this is visible.
    • mr.daus
      • Apr 2011
      • 98
      saya pernah mencoba memperbaiki CCD tapi CCD yg keluar kode 00225
      saya coba mengganti elco sementara ada yg berhasil,,
      yg belum berhasil saya coba lagi mengganti IC 12TZ51 kanibal dan hasilnya lumayan
      (tapi saya tidak memiliki ilmu dasar elektro,, semua itu cuma saran dari beberapa rekan saya)
      firdaus +(62)8195002007 firdaustrish@ymail.com
      • adhy
        • Feb 2011
        • 109
        just making a copies, i try to print was good.
        • adhy
          • Feb 2011
          • 109
          punya IC 12TZ51 ga?
          atau persamaanx aja?
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Do you have the same problem when you using ADF and copyboard glass?
            1. CCD Auto Adjustment
            COPIER>FUNCTION>CCD>
            CCD-ADJ
            2. CCD Adjustment Data
            all items under
            COPIER>ADJUST>CCD
            Use service manual.
            • adhy
              • Feb 2011
              • 109
              CCD-ADJ
              all items under
              COPIER>ADJUST>CCD
              Use service manual.
              no sir, if use The ADF copies are good, i had adjustment The CCD in service mode but nothing change. please help me.
              • adhy
                • Feb 2011
                • 109
                alright sir i will try it tomorrow.
